It is currently Wed Aug 20, 2025 4:06 pm
 Post subject: Binding Channel?
PostPosted: Sun Feb 02, 2014 11:59 am
First name: Danny
Last Name: Vincent
I've been meaning to through this out there. I'll be cutting another binding channel soon. I seem to consistently have the same problem. Say I'm using a .080 cutter and the same thickness of binding, it will be a nice flush fit with the sides at the lower bout, when the binding starts heading into the upper bout it becomes proud of the sides by .010 or so. It seems to happen consistently and I'm not sure why. I'm using a Fleishman type binding machine. I try to get the guitar on an average level. Maybe I need to raise the upper bout up a bit when cutting it?
Thanks for any help.
Cheers,
Danny
 Post subject: Re: Binding Channel?
PostPosted: Sun Feb 02, 2014 12:38 pm
are you using a cradle with the machine ? Make sure you use the top as the reference . the sides are most perpendicular to the top. If you set the back level to the table top you will cause the cutter to be off parallel and this will cause what you are describing.
PostPosted: Sun Feb 02, 2014 1:00 pm
First name: Danny
Last Name: Vincent
Yes a cradle John. I'll try what you suggest. Thanks.
PostPosted: Sun Feb 02, 2014 3:19 pm
This just happens. It is because of the inreased angle of the back above the waist. Just make your depth adjustment at the butt and carry on.
PostPosted: Sun Feb 02, 2014 8:15 pm
First name: Danny
Last Name: Vincent
I'll try paying more attention to the sides being vertical. In the past I have just gone with a level averaged over the whole body. I think it's usually more pronounced on the back. Logic would dictate that the depth would be the same all the way around.
PostPosted: Sun Feb 02, 2014 8:30 pm
Another trick is to use the edge of the router bit to fine tune the adjustment of the guitar in the cradle.
Bring the guitar up to the bit in all positions and make sure it is parallel to the sides. The head and tail blocks may not be perfectly parallel to each other and you may have to split the difference a little.
Last edited by Terence Kennedy on Sun Feb 02, 2014 11:27 pm, edited 1 time in total.
PostPosted: Sun Feb 02, 2014 11:07 pm
First name: Danny
Last Name: Vincent
Bring the guitar up to the bit in all positions and make sure it is parallel to the sides. The head and tail blocks may not be perfectly parallel and you may have to split the difference a little.
Thanks Terence! I will most defiantly have a good look at that.
Users browsing this forum: Bing [Bot] and 17 guests
